Sears Kenmore Microwave Stove Top Lighting Issue
wbnc
Tacoma, Washington
Hello,
The lights that illuminate the stove top for this microwave will not work. After we moved in, I noticed that the light bulbs were burnt out so I replaced them. That did not work. A few hours of work later I discovered that the sockets have around 30V AC no matter if the light switch is turned off, is on low or high. This microwave has a light timer feature which I have played around with, but I still cannot get the lights to turn on.
Any help is always appreciated.
WaveBlasterNutCase
ivoidwarranties
on the frying pan
Not supposed to have power if not turned on- sounds like another issue is in play. I would use it until it breaks, then replace it, and not worry about the lights.
Also- microwaves are one of the most dangerous appliances to play around with, imo. I am always nervously careful when I have to work on them. Been shocked by dryers a couple times but never want to get shocked by a microwave, which will shock you even if unplugged (the capacitor). Could even be fatal.
