Sears Oven won't heat
jrwit
Illinois
I was making brownies and heard a loud pop. The oven stopped heating.
we had recently replaced the igniter, picked up another new one and still no heat.
is there a fuse we heard pop?
the burners on the top still work.
help please.
Whats the model# of your oven?
jrwit
Illinois
model #
hi Jake
sorry I forgot that
really old tag to read....911.72?8710
serial # is 7U73243
Ok, not sure I can help you without a good model#, as I need to see a diagram of your oven to assist you.
You shouldn't have a fuse just for your oven, if this oven is really old, then its possible your safety valve thats bad.
Does this oven have a glow bar that ignites the gas? or a pilot?
jrwit
Illinois
model # 911.7278710
yes, glow bar - replaced in Dec and again after we heard the pop
serial # doesn't help? 7u73243
thanks
Here's the safety valve for your model:
Manufacturer's Number: 4334639
Also check the burner holes were your glow bar igniter mounts next to on your oven burner tube, make sure those holes aren't clogged.
