FIXED Second A105-8 Cartridge on Jenn-Air S161?
fb210
Colorado
S161
Jenn-Air
Hello, we purchased a home (built in 1990) about a year ago that has a Jenn-Air S161. We'd like to replace the grill with another A105-8 cartridge so we have four burners.
I purchased another cartridge on eBay, swapped it with the grill element, but the burners do not heat up. I did two things as a sanity check:
1. Moved our old cartridge to the side that the grill was on, all works as expected.
2. Tested continuity on the newly acquired cartridge and all seems to check out.
I opened both the newly acquired cartridge and our old one that still works. The main difference that I see is that the wiring is different between the cartridges.
Newly acquired cartridge:
1. A105-8
2. Three prongs, with the third being on the outer-most position of the terminal block
Existing cartridge:
1. A105-8
2. Three prongs, but the third is on the inner-most position on the terminal block
This prompted me to open both cartridges and compare. I see that both have similar burners, rated for the same wattages and voltages, but have slightly different (part?) numbers on them.
1. Small burner: 873 and 10849
2. Large burner: 873 and 1371
Existing cartridge:
1. Small burner: 891 and 18049
2. Large burner: 892 and 1450
Photo of newly acquired cartridge wiring:
Photo of existing cartridge:
Would it be safe to re-wire the internal wiring of the newly acquired cartridge to match that of the existing one that we know works?
Please forgive me, I'm short on appropriate vocabulary!
Yes. Just make sure the wiring to the elements will be similar as well.
fb210
Colorado
Thank you for responding! I think the sanity check of moving the existing cartridge to the other bay satisfies that - please let me know if you were thinking of something else.
