SGX68U55UC/D5 Bosch Dishwasher - water leaking from salt dispenser "nut"
kub1080
USA
SGX68U55UC/D5
Bosch
Hello - I have a Bosch dishwasher with a water softener. For about a week or so I have noticed water leaking from the nut on the side wall of the machine. I think this nut is where the soft water is dispensed durning a wash cycle. I ran the machine about 12 hours ago and the bottom of the dishwasher now has a good amount of standing water in the bottom of the machine. The water is also still dripping from the salt dispenser "nut" on the side of the machine. The unit still seems to run and clean properly though. After the cycle ends the tub is drained completely, but then water begins to drip out of the salt dispenser and the tub fills with water again. I run the machine quite often right now, but I am wondering if did not run it the water stop feature would kick in as the tub is continuing to be filled with water. Does anyone know what may be causing this problem and how I can fix it?
