Sharp 1505 display problem
jjag
United States
Sharp
Have a sharp 1505 model and the lcd display was only partially lit. bought new lcd panel and installed it and had even less display showing. put the old panel back in and it shows less display now also. any ideas would be appreciated.
thanks
John
The touch control panel consists of circuits including semiconductors such as LSI, ICs, etc. and unlike conventional microwave ovens, proper testing cannot be done with only a voltmeter and ohmmeter. The touch control panel assembly is divided into two units, Control Unit and Key Unit, and also the Control Unit is divided into two units, LSI Unit and Power Unit. Your symptoms indicate the problem is probably in the control unit. I'll give you the part numbers for both parts of the control unit. However, both parts have been discontinued by the manufacturer and show as no longer available. Whichever part you replaced, replace the other part. Here's the part numbers: CPWBFB060MRU0 and FPNLCB372MRK0
nyeurt
Fiji
Hello,
Just in case, also check the ribbon cable and its connector (if any) between the LCD display and the control unit PCB board for tears and/or bad connections; spray connector end with contact cleaner. All the best with progress.
