Sharp Carousel acting up
mekanikman_402
Omaha, NE
This happens randomly, but when i turn the microwave on sometimes it doesnt power up all the way like it should. Its like the motor is only running at 20% or something. I noticed that if i hit the top of it and then restart it, it will work normally. I dont know much about microwaves so any help would be much appreciated!
Happy Holidays,
Sharp Carousel
Model#?
?Motor?
Fan motor? Turn table motor? Stir blade motor?
Something loose maybe, a wire? A stuck/sticky relay?
mekanikman_402
Omaha, NE
Sorry about that. The model number is R-320HW. I noticed that whenever it does that, the turntable also turns slowly. Sometimes it will just start slow and slowly pick up speed til normal. But earlier i started it and it acted like it was barely running. I smacked the top of it and turned it back on and it ran normally. I havent used it since earlier.
Unusual problem.
Kinda -sounds- like "feed back power" ( something has opened up and the power is running through something else before getting to the device that is should be getting too = lower output and slow itesm ).
Turn table, magnetron and lights go through the door switches, definetly check those for any burnt wire and check the switches themselves.
http://www.applianceaid.com/micro2.html
Failing those, relays on the main PCBoard turn things on and off, they would be suspect if all else checks ok.
Counter top style.
Chan
Trinidad & Tobago
We have a Sharp Carousel with Browner Model No. R-4897 that was manufactured in January 1997.
When we close the door, the light remains on sometimes - we normally have to nudge the bottom of the door into place before the light goes out and we can operate the microwave.
Couple days ago we came home to meet the microwave light on and the door open - the door refuses to close - the two (2) black prongs on the door appears to be loose and the door is simply not staying close. All the controls appear to work, except START - we can set the time, displays correctly and works fine; same for kitchen timer; power level, etc. We can enter the cook time, but START does not work. We have manually held the door firm shut, but the light still remains lit - no beep is heard when we press START. Please help!
Need to check the door switches, door catches that hold the switchs and the door keys on the door itself....if broken/loose/out of position/burnt. Sometimes the metal bracket inside the door than holds the door key(s) in place will break and the door doesn't close properly.....would have to be investiagted.
