Sharp Microwave cooks too hot at low setting
PRMercier
Houston, Texas
R410LW
Sharp
I have a three year old Sharp microwave model #R-410LW. It seems to be cooking too hot. When I set the power to the lowest setting (#1), it still seems to be operating at a much higher setting. For example, I tried melting cheese and it burned the cheese very quickly at the lowest setting. Is there a way I can test the unit, for example, by seeing how long it takes to boil water at different power settings?
