Sharp Microwave Display not working
kannen
imported post
After moving the unit, many of the sections of the digital display numbers don't come on.
This leaves us with no way to use anything except the timed cooking and then we have to guess at what the numbers are. Sharp Model R530-BS. Any suggestions?
imported post
Sounds like maybe connections to the display got damaged in the move. I don't know if it is possible just a connection got jarred loose in the move but otherwise, replacing the control and display board (see the following link) may be required to correct the condition. :?
LINK > Sharp R530BS Control Circuit Board
JMO
Appliance411.com
=D~~~~~~
[font="Arial, Helvetica, sans-serif"][/font]
