Sharp Microwave overoven: Works but no display.
simonz
Santa Cruz, California
R-150X
Sharp
I have a Sharp R-150x above oven microwave. It works fine, but there is no display whatsoever ... nada! The unit is seven years old, but was hardly ever used.
Two sets of questions:
1. Is it easy to get to the display electronics? If yes, how? Do I need to drop the unit to access?
2. What are the most likely causes of complete display failure? How are these fixed? Are the parts expensive? (Note: I can buy a new above oven unit for $200-300.)
- Simon
simonz
Jeff -
Thanks for the quick response. I don't know the exact model number. I'm going off of the models listed on the cover of the user manual. It is in the R-150x series, but I don't know which one. Where do I find the exact model number? Do I have to drop the unit to get the number?
I'm not sure what you mean by "OTR Style". My microwave is mounted above the oven. It has a light and an exhaust fan. The unit is at another location (not my home) so I can't provide a photo immediately.
I found a video that shows how to remove the display. Assuming I can do it successfully, what info do I need to provide you to get a replacement part(s)? As I said, the microwave works fine except nothing at all appears in the display.
- Simon
Only reliable place to look for a model# is on the product itself.
Where is my model#, I need a part, where should I look for my model number
Around the door opening, on the bottom/underneath.....nope.
Over The Range.
Full model#.
simonz
Jeff -
Again, thanks for the quick reply. Since the unit is at another location, it will be a few days before I can get the model number info.
Until then ...
- Simon
simonz
Over The Range.
Full model#.
Jeff -
Sorry it's taken me awhile to the get the info. As I said, the microwave unit is at another location. Here's the info:
1. Sharp OTR Microwave Model R-1502. Manufacture date Sept 2003. Exterior color is creamy white - ivory or almond.
2. All microwave functions seem to work, but there is no display. It is completely blank.
So ...
1. How much does the replacement part cost?
2. Is it easy to install? Does it come with installation directions? I would hate to buy the part and then not be able to figure out how to install it.
Thanks for your help.
- Simon
simonz
No worries....fairly easy to replace....power off first! ;)
Pc board with display
No instructions with parts.
Jeff -
I replaced the part and it works, BUT ...
The display seems dim. During the day with the kitchen light on, it's visible but certainly not as bright as the other digital displays in my kitchen ... and ... not as bright as I remember it.
Is there a brightness adjustment? I don't think so because I didn't see any jumpers or dials on the board, but I may have missed it.
I guess I can return the part as defective and try another one, but I rather not. Any suggestions?
Thanks again for the help.
- Simon
