banamber
- R-120DB
- Sharp
- More than 10 years
My spare microwave is a Sharp R-120DB. The other day I got it out. I heated up a hotdog in it and it worked fine. After that it wouldn't heat anymore. I checked the interlock switches, they're all working. The thermal cutout is closed. C/T fuse is closed. Rectifier diode looks fine. I haven't done any testing on the HV parts yet (Including the rectifier). While this microwave is old (Manufactured in 2000), it doesn't have many hours on it since it was always sitting around as a spare.
The top of the machine, around where the magnetron and HV cap are does get warm after running for a minute.
I also hooked it up to my Kill-A-Watt Meter. It's only drawing 2.99 amps and 310 watts. According to the manual, it should be drawing about 9 amps (1030 watts). Does this indicate the rectifier diode has failed?
