Sharp microwave R-420LK does not power up
ocn
SC
R-420LK
Sharp
The Sharp R-420 LK microwave we use in a toy hauler has suddenly stopped working. No signs of power. I've verified the outlet has power, moved into shop to bench test things. Fuse is fine. Capacitor seems to test out as OK. Door switch appears to be working properly. What should I test next?
ocn
SC
Dan O. I found 1 fuse like those you posted it has continuity, so I'd guess is it ok. The traditional round tube fuse also checks out OK. On the circuit board there are 2 of these and when checked with an ohm meter they do not have continuity. But I have no idea if they should.
I
ocn
SC
Upon closer inspection I see that the item on the circuit board is actually a relay of some sort, so it might be normally an open circuit with no power.
I have no idea how to test any of the components of the circuit board. If the board was found to be defective, the whole board would usually just be replaced.
Someone will have to look at the unit's wiring diagram to determine other possibilities. Most failures would not stop the control from lighting up, just heating or fan functions, etc..
