SHE3ARF5UC/14 Bosch E25 Error - unusual reasons?
Paradia
Toronto
SHE3ARF5UC
Bosch
Hi all.
I've been plagued with the E25 and E24 code for years with my dishwasher. I typically clean the filter and try to clear the impeller of any food-stuffs. Recently it has gotten worse and worse. This weekend I took it apart and removed the impeller and rinsed out the drain hose. There were no significant blockages.
It ran clean the first time, but the next load I ended up with the E25. I tried my typical approach of running the Rinse and Hold 9 minute option to see if that would help. No luck... just constant E25's.
I'm tempted to get a new impeller or pump, but the more I think about it the more I think it may not be either one... and here's why:
The E25 almost always only pops up at the very end of the wash on the last draining of the dishwasher. When I run the 9 minut Rinse and Hold the dishwasher starts by draining itself, which it always does with no problem. So the issue does not seem to be that it can't drain itself. It seems to be that it doesn't drain itself at the end of one of the wash cycles.
Before I start ordering parts and blindly replacing them, does anyone have any thoughts as to what the actual issue may be or how I can more concretely diagnose the issue?
Thanks in advance...
Alex
Hi Alex,
We need the model number of your machine first. SelectPlus 50 isn't a model number.:)
The model number tag should be inside the door.
Paradia
Toronto
I'm looking at the tag on the inside of the door and what is labelled as the model number looks
SHE3ARF5UC/14
FD940600344
There was also a number that looked more like a model number SN6P5B.
Let me know if I need to keep looking!
Paradia
Toronto
Thanks Jake.
Yes, I've gone through those steps many many times over the last couple of years. As per the original post what is making me think that this may not actually be an issue with the impeller or the pump is that the dishwasher drains no problem when I start the next cycle - so it doesn't actually have a problem with draining itself, it just has a problem with draining itself at the end of a regular cycle.
So what happens:
1 Run a regular cycle (Heavy, Normal, Auto, Delicate, Express)
2 It fails with E25 at the end of the cycle with water in the bottom of the dishwasher
3 I start a 9 minute Rinse cycle - the first step of which is to drain any existing water.
4 It drains no problem
If the impeller was jammed or the filter etc were out of place I wouldn't expect #4.
Thoughts?
Alex
I agree Alex, that's why its throwing me for a loop too.
Hopefully another tech. that's seen this particular problem can shed some light on this for us.:)
Paradia
Toronto
Thanks again Jake. At least I feel better that it's not an easy diagnosis :)
Any way to mark the thread for other Techs to look at? Or is it a 'just hope' scenario?
Nope, other techs will see it when they come, if no one responds that indicates they don't know either, then I'd suggest having a Bosch Tech come to your house to see what's going on: bosch-home.ca/en/service/contact-us
Glad to help Alex.:)
tejch
Slovenia
We have exactly the same problem with our dishwasher. Did you find out what the problem was?
Thank you in advance
Paradia
Toronto
Alas, I have not. I just clean the filter etc frequently and take a part the system occasionally to really clean it all out.
Paradia
Toronto
@Jake - The dishwasher has been continuously going into E25 errors (every time). I replaced the impeller/drain pump to no effect.
I've replaced the drain hose and cleared out all the hoses.
I'm assuming at this point that it is the sensor. Is there a specific sensor that i can replace?
I have no clue my friend, I don't work on Bosch.
Ales
SI
It seems that when pump rotation is not entirely blocked but only obstructed, E25 is signaled on Bosch only on end drain cycle and not on other drains between washing program.
The control board circuitry measure pump electric current load and when exceeded for any reason, it signals E25 says in service book.
In my case blockage was built from bucket of fibers and/or hairs around steel axis just under impeller caused pump motor needed more power to turn and escalated current.
I couldn’t even imagine how many fibers manage winded around steel pump axis in 7 years and breaking rotation and escalating pump electric current load.
I remove pump after opening down front board of dishwasher. After that I pulled impeller together with fix magnet rotor and rotor cover from pump. Then carefully cleaned axis between impeller and front rotor cover with forceps in small sharp knife. Also checked ohm resistance of stator which was ~83ohm on both contacts, just confirming service book data.
After described cleaning, dish washer finally and victoriously ended program without water inside and without error.
Before this consideration I open all parts of drain path, observing several dish washer working cycles without any clue what going on as Paradia also described.
The 'mission critical' part for mostly preventing such clog and repairs is tightly closed filter board which prevents fibers to enter to the pump chamber. I found filter previously just slightly open several times .
Because grey indicator which guards proper filter lock position is almost invisible I now added piece of red plastic to ensure easy visibility of properly locked filter.
