SHE4AP06UC/06 Bosch dishwasher stuck - wash cycle lights on but not responding
Tim&Bosch
Cypress, TX
SHE4AP06UC/06
Bosch
Dishwasher fills up with water, then stops with wash cycle lights remaining on. I already replaced the drain motor. When I open the door and hold up the float in the bottom to drain the water that is there, it makes a grinding noise but water does not drain.
Hi Tim,
Did you just replace your garbage disposal, then this problem with the NO DRAIN started?
If not, then check your check valve first.
The check valve is underneath the machine where the drain hose connects to the sump.
When you click the check valve part link below, you will see a video of how to remove to see if it's partially clogged up and how to replace it.
Here's the check valve for your model:
00611320 Check Valve
