- SHP65T55UC/07
- Bosch
- 1-5 years
Hi Having a hard time finding a leak in my Bosch Dishwaster model # SHP65T55UC/07. Its pretty sad , I do have an extended warranty with Lowes, I am on my second call in for service and this service person didn't even show up the first service man came out and said there is nothing wrong with it reset the code E15 and on his way he went . So I am learning or guessing Lowes contracts out to some pretty low rated repair service companies. I know how to fix things . So I already took it apart and found the styrofoam disk that was giving me an E15 code . Cleaned out all the water and ran the machine with some red dye and have been having a hard time to spot where the leak is coming from . I for sure see its coming from the back of the machine the insulation is all wet in the back of the machine on the bottom. I looked inside the machine and the back panel has a black gasket that seals the back panel to the sides and bottom basically a gasket that goes all the way around . Its coming a part It for sure is degrading and needs to be replaced . I looked at the parts list and cant find it . I called Bosch and they said they cant find it either and wanted me to hire one of there techs to come out. I am not doing that. So need help to find out where to buy the gasket and how I might replace it. I also came across a round gasket that goes around the pump motor that sources say can be the problem the kit is a 12005744 Bosch Sump Pump Repair Set. I have not yet received this kit when I do I will put it in, but I don't see any water coming from the pump. So any help on here will be appreciated. I attached a couple of pit of the inside of the machine where the gaskets are coming apart
