SHP65T55UC/07 Bosch Dishwasher - Removing control panel from front panel
SatelliteMan
Gettysburg, PA
SHP65T55UC/07
Bosch
Hi gang, this is my 1st post.. Got an Error 15 (water in the bottom leak detection) and need to pull off the front panel, All the videos make it look easy... It was, UNTIL I went to pull the panel off and the control assy. is attached and I can't determine how to disconnect it, there isn't enough space to see where the connection points are.. can someone give me some blind guidance please??
Watch this video below, it shows how to replace the dispenser, but in your case--->it also shows you how to remove the console and front panel.
SatelliteMan
Gettysburg, PA
Thanks, this nearly got me there.. but a step has been missed.... the picture I've added shows him with the control assy in his hand, but never shows how he separated it from the front panel, It's like something is holding mine in place that I can't find.
Ok, I don't know then, sorry. That's the closest I could come.
Hopefully another tech. or member can show you how.
