Wally619
- SHP65TL5UC/07
- Bosch
- 6-10 years
Hello all. I am new here. I though I would try to pick your brains regarding a problem which has been driving me nuts!
I have a Bosch SHP65TL5UC dishwasher which was showing error E09. It would run close to a full cycle buy just have no heat at the end, so the dishes stayed wet. It turned out to be a burned-up heating element on my circulation pump with heater.
I looked for the replacement part on appliancepartspros.com, but it was confusing -they indicated bosch # 12008381 for one search, but also bosch # 00753351 in another search. I purchased the 00753351 part. When it arrived I immediately noticed it was bigger than the original. However the hose inlet/outlet and electrical connections matched with no issues. So I installed it.
Everything seemed to work well at first until I noticed the dishwasher would only run a few minutes before beeping to indicating it was done. The "speed perfect" cycle is supposed to be 90 minutes, but it will sometimes run only 2 minutes, other times 45 minutes, but rarely the full 90 minutes. It always beeps at the end to say it is done and flashes time 0:00.
Any ideas what is happening here? Thanks in advance for any help you can offer!
