SP427
- SHU66C02UC
We had trouble free 6 years with our bosch dishwasher. Last month the control module relay fry( K1 relay-smoked/burned the old board ). Just before the relay burned, it would stay on the last min of the counter for a while. Everything was working prior to the control module board frying.
1. Replaced the Control module and the circulation pump did not come on. It just fills with water and drains a little, kinda pulses with water in and draining. When you cancel the cycle it drains fine and turns off. Would say you could smell an electric burning type odor when this was first installed, but that could be from the old board. The old board seemed to get very hot when the relay burned. We liked this dishwasher and felt it was worth replacing the Circulation pump and have another 10+ years of life.
2. Replaced the Circulation pump with a brand new one and it does the same water in and draining! I tried adding a couple cups of hot water when it was filled with water to see if the increased water level would cause the circulation pump to come on, but no changes. The old motor seemed to be fine, no play in the bearings or impeller. This is turning into an expensive project and I am still washing the dishes by hand.
3. Let's throw more parts into the dishwasher. This evening, replaced the Water heater assembly, which included the NTC sensor, aqua sensor, and other switches that are part of the Heater assembly. New float switch and a new water inlet valve. Does the same thing, fills and drains and the circulation pump never turn on! The dishwasher drains fine when you cancel a cycle and the various run cycles appear but the circulation pump does not work. The drain pump seemed kinda hot after running for a while constantly draining/filling.
At this point I am down to a few original parts such as the drain pump and soap dispenser. Also the 186963 PC board(just a display or does it also control the circulation pump???) and the wiring. The wiring looks and feels ok and all the wires are connected.
Starting to feel that I should have ordered a new dishwasher when the control module burned up. Has anyone run across this problem before?
