SHU6805UC Bosch Dishwasher No Water
Sneed
New York
SHU6805UC
Bosch
My Bosch dishwasher would not turn on. I repaired the faulty wiring in the bottom front of the unit. Now it lights up and I hear it running but no water is let in. The feed pipe valve is definitely open. There was no such problem before the electrical issue.
Did you remove the water supply line and get something to catch water in to make sure you have water pressure? I remember a service call with this same issue, and it was the customers water supply valve was on, but no water was coming through it.
Do you hear and feel the water inlet valve on the machine vibrating like its trying to put water in, when it should be filling?
The feed pipe is run off the hot water pipe connected to the sink right next to the dishwasher and that water is flowing normally.
Ok, I'm not familiar with Bosch and I can't locate the service manual for it.
Hopefully another tech or member that's seen this problem and fixed it can shed some light on this issue.
