SHU9925UC/14 bottom leaks/stops running after 30 seconds/ stuck in the countertop
westalone
San Francisco
SHU9925UC/14
Bosch
Hi folks,
Happy new year! Any suggestions/advice are welcome!
First, the old Bosch DW stopped running after 30 seconds (I heard the water flow sound and the sound of motor), and I spotted accumulated water leaking in the bottom of the DW (see picture).
After I read some threads in this forum, it may be duo to leaking in bottom and the sensor detects the leaking and the circulation pump stopped.
Then I started to try to uninstall it,
and the bigger issue came out. It seems the machine was stuck under the countertop. I did not see the screws to hook the two brackets to the countertop. The plywood of right side was warped up due to moisture compared to left side (see the pictures). I tried to lower the dw by rotating the right leg, but it seemed stuck and I can only lower the left leg. Now I can only push the dw back a little bit and wiggle it left to right, but I could not take it out.....:(:( If I cannot take it out, there is no way to fix it or even replace it....
Any suggestions are welcome!
Thank you very much!
