SHX46B05UC/14 Won't Fill!
adanac
new york
SHX46B05UC/14
Bosch
We have a Bosch SHX-46B05UC/14. Recently, it stopped working with no lights on the buttons. I successfully replaced the control unit and then found it wouldn't fill. So, I replaced the intake valve but, alas, it still won't fill. What's the next step?
I haven't worked on many Bosch machines over the years but see if this works and check for any error codes. While pressing any two wash buttons, turn the machine on with the on/off switch then release the two buttons.
43823
LED B will be lit and LED C will be flashing. Push button "B" repeatedly until the display shows “P1” or until LED “C” is lit. Then push button "C" to start a test cycle.
adanac
new york
Fascinating, thank you. Our unit has no LED display. If there is an error code, how will it be shown and de-coded?
adanac
new york
Thank you. Will a code come up right away or after the test cycle. After pushing the buttons in the sequence dictated in your first graphic, the C light blinks. But that is before the test cycle, which is running now.
