SHX68T55UC/07 Bosch Dishwasher error 23 unable to clear, no drain no start
tmol
florida
SHX68T55UC/07
Bosch
test voltage at drain pump connector reading is about 40 volts. also tested with amber light troubleshooting little voltage tester . light is weak and flickers with when relay is clicking on control board. I also get a e 25 error. but the E 23 is on and will not clear. thanks t mol
Hi tmol,
E23 error code indicates there is an issue with the drain pump. This happens when the dishwasher pump is blocked, clogged or when the drain pump is faulty.
00631200 Pump-Drain
Check for blockages first. Let us know what you find.
tmol
florida
update--- lower wiring harness is bad and needs to replaced. I will update part # of wiring harness thanks tmol
Excellent tmol, glad to hear the new wire harness fixed it. (y)
tmol
florida
new update ----new wiring harness and also new main control board per bosch to replace. still getting e 23 code dishwasher will not go into drain mode. just issues error code. e 23. that's not fix. and this per bosch. thanks t mol
So what did Bosch say was the fix to the E23 error code?
tmol
florida
replace lower wiring harness and main control board. but still getting e23 code. there is recalls on some bosch dishwashers but this model is not effected.
thanks t mol--
So what are you planning on doing now? Or is the customer just going to buy a new dishwasher?
