SHX7ER55UC/50 Error 15 and Flashing Sparkle
Pelgy2
California
SHX7ER55UC/50
Bosch
Was getting E15 error code, water in bottom of dishwasher. Tried cleaning filter, checking drain pump impeller, tilting back 45 degrees, removing float. After all that, now we're getting a flashing sparkle symbol with nothing else on the display. Flipping breaker and holding start button three seconds (and longer!) doesn't reset it. Any thoughts?
I located the Bosch error code list: https://drive.google.com/open?id=19958SUT20qoMofjr7dXNEHp2cXv_ewr7
Wash cycle abruptly stops, dishwasher drains intermittently, Sanitized LED flashes and E:15 shows on display. Check float switch. Water in base activated float switch and dishwasher can’t be shut off.
--->Remove debris / obstructions from drain pump / drain hose. Remove water from base.
--->Make sure float & float switch aren't stuck.
--->Make sure water inlet valve isn't stuck "open". Check inlet hoses for leaks. Remove water from base.
