Slow Spin
Trout27
imported post
I have a Kenmore 70 Series top load washer, Model 110. The washer will cycle though all cycles but the clothes come out very wet. The problem just began happening and my wife notice a slight burning odor but no smoke.I ran the washer though the spin cycle and it does spin although it lookslike it is spinning much slower than usual. Any ideas what it could be??
imported post
**Kenmore 70 Series top load washer, Model 110**
70 series is a name and the 110. is the beginning of a full model#.
Does it look like either of these?....
Some model# helps.
Trout27
imported post
Sorry about the Model #, the full number looks to be 110-92573210. In looking at the 2 pictures that you posted, the full back more closely resembles my washer although the fill couplings are different. The back seems to be a full panel so I believe that this is a Direct Drive model.
imported post
**110-92573210**
Yupper, comes up as a direct drive style.
**I ran the washer though the spin cycle and it does spin although it lookslike it is spinning much slower than usual**
A copy:
[align=left]Quick tips....Slow or no spin....[/align]
  1. [align=left]Lid open. [/align]
  2. [align=left]Lid switch defective. ( Very Common problem ) [/align]
  3. [align=left]Lid switch disconnect plug open. [/align]
  4. [align=left]Clothes between basket and tub. [/align]
  5. [align=left]Wiring harness. [/align]
  6. [align=left]Weak clutch. [/align]
  7. [align=left]Timer switches. ( possible not allowing the pause required for the transmission to set up to spin ) [/align]
  8. [align=left]Motor. [/align]
  9. [align=left]Cam driver on basket drive broken or basket drive weak. [/align]
  10. [align=left]Spin tube. [/align]
  11. [align=left]Clothes between basket and tub. [/align]
  12. [align=left]Notches in drive block worn out and not engaging basket drive shaft. [/align]
  13. [align=left]Broken motor coupling. See coupler page[/align]
  14. [align=left]A bit on how the washer works[/align]
[align=left]jeff.[/align]
