SMH1816S Samsung Microwave Latch Broken
Beth Penfold
Indiana
SMH1816S
Samsung
Default Samsung Microwave latch broken
My microwave wasn’t latching shut. We have to hold in closed in order to use the microwave. I took off the panel and saw that the latch on the inside of the door (that the spring connects to)looks broken. The spring has nothing to connect to on the inside. Is there any fix for this other than buying a new door, or worse, have to buy a new microwave?? Please help.
Which end broke off? From the plastic door key? From the tab in the inner door panal?
Door-Hook-DE64-01308A-01095122.jpg Microwave door key or door latch
Beth Penfold
Indiana
Hello!
It is broke on the actual inner door. I had assumed the door key was the broken part so I bought a new one. When I went in to replace it that is when I discovered the little latch was broken on the door itself. That new part didn’t help me at all. Now I’m afraid the only way around this is anew door or new microwave.
I usually drill a small hole next to where the original hook broke off and use the hole to hook the spring into.
