SMH2117S/XAA-0001 No Power Samsung Microwave
dmo069
Allen, Texas, United States
SMH2117S
Samsung
Had a problem with door switch. Unplugged main board and removed switch to determine part number. Switch fell apart. I put it back together. Then I proceeded to plug main board in wrong. Loud pop. breaker went out. I can't believe I missed the color coding when putting back. Replaced main board.
Outlet is good. Main fuses have continuity. Some thermostats have continuity and some don't. 2 near front, right bottom of chassis - Left one does not and right one does. 1 at top of chassis near cooking chamber has continuity. 1 above magnetron has continuity. Not sure where to go from here. Any suggestions greatly appreciated!
I don't have a wire diagram for that model. Can you post a copy of yours here? It would be most helpful.
That works! So the microwave is completely dead, no display and nothing works, correct? Locate connector CN101 on the board and check for 120 VAC
According to the wire diagram, all the TCO's are normally closed. Take the two wires off the one that was open and temporarily short them together and see if it turns on.
Do I check the black and red cable going to that connector?
OK, recheck the main fuse and the high power fuse on the noise filter. If both check good measure the voltage at the in connector and out connector on the noise filter. The in connector has a black and a white wire and so does the out connector. You should have 120 VAC both times.
Should I be able to measure any voltage across the fuses?
No, you have 120 VAC coming out of the noise filter so locate CN101 on the board The black wire becomes an orange wire and the white wire becomes a gray wire, Check for 120 VAC across the two wires in the CN101 connector. Here's a diagram:
The manual just shows the one board. In the one you just posted follow the steps for Tip 1-9 step 2 on page 18 and check for 120 VAC if that's your board.
No problem, Your new board is bad. Can you exchange it where you got it?
That's supply voltage for the entire machine. If a fuse was open the voltage would be 0. That also supplies the low voltage for the display
