SMH9151 Magnetron Fan wiring
Cicada17
Washington
SMH9151
Samsung
We disassembled a Samsung SMH9151 microwave and am trying to figure out the wiring for the magnetron cooling fan (SMF-437UA3).
There are three wire connectors.
One is Line.
One is High speed.
One is Low speed.
How or can I tell which is which with a multi-meter?
Wiring digram?
Is there no wiring diagram in the microwave? It's frequently pasted onto the inside of the outer cover.
Usually the resistance between the high and low speed terminals would measure the highest resistance. The other terminal should be the common (what you're calling Line). I don't know what the resistances of the individual speed windings would be to tell them apart though.
www.Appliance411.com
=D~~~~~~
