SMH9187ST Microwave Fan turns on when door is opened
dksagun
NY
SMH9187ST
Samsung
Microwave functions okay, but fan turns on when door is opened without selecting any microwave functions. Turntable does not rotate when door is opened, but fan turns on. Magnetron was replaced two months ago and all was working fine up till now. Please advise.
It sounds like it could be a door switch issue. Try checking the door switches for continuity with your meter. Check the switches by opening and closing the door and not by pushing the button on the switch.
Samsung Microwave Model SMH9187ST Parts
