FIXED SMH9187ST Microwave run but does not heat
dksagun
NY
SMH9187ST
Samsung
Microwave runs but no heat. Verified all the door switches work. All thermal sensors seem to be okay. I think one is normally open (KSD-40LC70). Please confirm. Verified 120VAC to the input of the high voltage transformer while the microwave is running, Check diode out of circuit and it is dropping 3.7 Volts, so I think that is okay. Suspect the magnetron at this point as the connectors are somewhat charred. See attached image. Anything else I should be looking at?IMG_1755[1].jpg
Please only start and use 1 thread for this microwave, I see you started 3 threads on this.
No I can't, because I don't work on microwaves, only Jeff and Rick do.
