Sparks, flames and smoke!
cowman
Utah
While thawing hamburger, the microwave began to spark then appeared to be burning...actual flames on the inside behind control panel and then smoke. Stopped microwave immediately. There is a small burn mark on the inside by a removable panel. I removed the panel and I can see an orange fuse or some kind of sensor that appears to be burnt. Microwave display still works and comes on and turn table will run but I have not let it run long enough to see if it heats up. Dont want to burn the house down!
Any ideas of what this part is and can it be replaced.
Thank you.
cowman
Utah
Ok pretty sure that is not the problem because it is pretty clean. Flames came from behind the cover. what about the sensor/fuse behind it. It is clearly burnt. it is orange and grey and the top part of it is burnt.
cowman
Utah
Update
made sure everything was super clean. Started microwave...more flames within 5 seconds! The wave guide cover now actually has a hole burnt clear through it. Whatever that part behind the cover is, it is actually shooting flames when microwave is on.
