Speed Queen AWM432W
Philadelphia
I have an older Speed Queen Model number AWM432W that is having the following problems.
1. Does not drain water during spin cycle, typically only half the water drains
2. It does not stop at the end of the current cycle its on. So for example if you select regular it just goes past the stop and continues to the delicate cycle.
Any suggestions?
I'm not sure if there is two problems or just one. It sounds like you need a pump. You might be able to remove the hoses and clean it out
AWM432
