Speed Queen washer AWN432SP111TW01 making a loud banging noise as it starts the spin cycle
Wasatchcomm
Wyoming
AWN432SP111TW01
Speed Queen
My washer is making a loud banging noise as it starts the spin cycle
Almost like something is hitting the side of the cabinet. And it increases as the tub spins faster.
It’s not the drain pump
After cycle is complete
I can grab inner tub and move it slightly
  • 66930648910__F2B7046F-7800-4563-88A7-FB2E15DDE938.MOV
    899.7 KB
It sounds like the drive belt is possibly got a bad/worn spot in it.
Here's the drive belt for your model:
Belt 38174
Also check the idler pulley the belt rides on to see if its wobbling on the metal idler arm shaft.
Here's the idler pulley for your model:
38225P Pulley (wheel),idler
This video below gives you the general idea of how to access both, It says Amana, but its basically the same as Speed Queen.
