rwmair
- AWN632SP116TW01
- Speed Queen
- 6-10 years
Seeking help with a problem with a SpeedQueen washer we inherited with a new house.
Washer seems to work fine, but excess foam is generated only at the drain outlet into the wall. The water from the foam seeps out of the outlet receptacle and runs down the wall, where its done minor damage to the dry-wall.
Every web search on this topic shows photos of washers with foam bursting out the top. Not here - we use minimal detergent, and now are using a "low-sudsing" detergent to boot. Opening the lid to the tub during the cycle, I only see a tiny ring of small bubbles around the edge of the tub. There's a small amount of foam generated when the wash cycle drains; more foam generated when the rinse cycle drains, and the most of all during the spin cycle. Photos attached. Sometimes I repeat an entire wash cycle without adding further detergent - the foam deceases in quantity, but is always there. Then the next time, its back to the same amount of foam as before.
We've had a plumber look at it, who referred us to a drain company. They came and put the camera down the drain, and also checked the vent stack, and said the pipes were excellent. Just use less detergent! That was $350 well spent. :-(
I read the manual which described the importance of not putting detergent in the agitator, so I pulled the cap off per the instructions and washed it out. It seemed there had been a lot of detergent in there, but that should now be clean and the foam continues unabated. Is it possible other areas of the washer drain are coated in detergent residue (if previous owners used too much detergent or or used it incorrectly) that is slowly seeping out with ongoing use? Is it worth replacing the black drain tube?
Any suggestions would be appreciated.
