Speed Queen won't spin
Mike CT
Connecticut
Hello,
I have a Speed Queen SWF-561WH that recently stopped spinning. It's spitting out and error code of E:dF, which means there is a drive failure.
This could be caused by a bad motor, belt, or tachometer sensor (in the motor). It's not the belt. The motor is not spinning at all. Anyone know how I can test the motor just to be sure it's toast before I order a wrong (and expensive) part?
Mike
Please check your model# again, I can't pull any info up on that model#.
Oh ok, Thats probably why I couldn't locate it.
Hopefully another tech. or member that has information on this can help you out.
