- SSD25NBL
- Amana
- More than 10 years
Hello all,
I sure could use some help on fixing this old timer. Normally, I probably wouldn’t spend the time or energy trying to fix this but I really want to for sentimental reasons.
Ok, so here’s what’s going on. Recently, the evaporator fan stopped working and evaporator coils iced up. The compressor and cold control work fine. I have tested and confirmed that the evaporator fan motor and defrost T-stat are good. I know these issues are sometimes caused by a defective adaptive defrost control board which I also know are prone to failure but have even replaced that with a known good board. Still, the evaporator fan motor won’t run. The only time I can ever get the fan to run is if I bypass the fan neutral wire (brown wire) and connect it directly to a ground so I know it has some sort of a ”neutral “ issue.
Additionally, when forced into defrost mode, the compressor shuts off as it should but the defrost heater also won’t come on. Probably also a “neutral“ issue. When testing the adaptive control board, I should be getting 120 volts off pins K (yellow wire hot) and pin D (brown wire neutral) but I don’t. As mentioned before, the only way I can get the 120 volts for the evaporator fan is to pick up the neutral somewhere else or just ground it.
I’m guessing that since I can’t seem to get the “neutral“ from the control board, there must be something that actually tells the board when to turn on and off that neutral. The only component that might be in question is the actual defrost heating element itself but I don’t see how that could affect the control of the neutral to the defrost heater itself or the evaporator fan. I’m completely at my wits end. Does anyone have any idea on what’s going on with this? I would so greatly appreciate any thoughts anyone might have. Thank you so much in advance…
Stuart D.
Portland, OR
Stuart D.
Portland, OR
