stack
jayjay
imported post
hello everyone first time using your site,
i got an lsg1000 stackable.problem is no motor .fills thats it.i diagnosed bad relay?i looked up online at sears and came up with a 33002969.i installed still no motor.i took # off part 901961 changed to a 206824 and NLA according to marcones site.now i dont if its me or wrong relay.some backround-i direct tested motor checked good,power to lid lock,lid lock good,reversing relay clicks so its getting power,i swapped reversing relay anyway,nothing.used tester to test board showed good.am i missing something or is relay wrong?any suggestions?
thanks,
jay
imported post
**i looked up online at sears and came up with a 33002969.i installed still no motor.i took # off part 901961 changed to a 206824 and NLA according to marcones site.now **
Relay, spst, the manufacturer has replaced part number 901961 with this item, part number 33002969.
**problem is no motor .fills thats it**
Common trouble makers:
- washer plug unplugged or blown fuse!! ( most of these units have 2 power plugs )
- lid switch
- motor relay
- motor
- reversing relay
- umbilical cord
- no power from the board to operate the relay(s)
This here may also help.....
jayjay
imported post
thanks jeff
most of those items have been checked.i didnt see a fuse in machine itself.maybe ill pull it out and check umbilicle cord and wiring.ill let you know how it goes.
thanks again
jay
imported post
**i didnt see a fuse in machine itself**
I don't remember seeing a fuse inside of this style either, newer ones did in the lid switch circuit but not on the SE/SG1000 series.
jayjay
imported post
i didnt get to get over there today but what i did realize is that this relay is same part # as dryer relay.could that be possible or is that where the descrepency is coming to play?
jay
imported post
**could that be possible or is that where the descrepency is coming to play?**
Same relay.
4 wires, 2 for the device and 2 from the control board to operate the relay.
