Start/Stop Flashing on Kenmore Elite Dishwasher 665.13793K602
mkirpalani
M4L2S5
665.13793K602
I have a Kenmore Elite Dishwasher 665.13793K602, Serial FU0505046
The Start/Resume light will flash mid way through a wash on any program, if I press start/resume then it typically completes the cycle.
Sometimes it will shut off all indicators and will not respond to button presses, then after some time it will automatically power back up in the flashing start/resume mode and again if I press start/resume it completes the cycle with no issues
I assume this behavior has something to do with the thermal sensor as when I opened the control panel I could see the previous owner had replaced the thermal fuse and there was a brown spot where the previous fuse must have blown ? I contacted the previous owner and he sent me and email stating that he got a replacement part from Amazon
Would replacing this with a genuine OEM part fix the issue described ?
What part # would I need and how much would this cost ?
Yes, it will.
Just to let others following your thread know: Whenever you replace the thermal fuse--->You ALWAYS have to use the OEM thermal fuse and You ALSO must install the new wires that come with the thermal fuse kit TOO, or it will cause the thermal fuse to keep blowing out continually.:)
Here's the OEM thermal fuse for your model(Video Included in part link)
W10258275 Thermal Fuse
RepairClinic ships to Canada:
