- 253.74173401
- Sears Kenmore
- More than 10 years
Kenmore model 253.74173401, top freezer purchased in 2005
Problem began with temp not as cold as it was, gradually boosting dial to colder and mystery water in the bottom of the fridge.
Soon after noticing more water, noticed frost in the freezer vents. Removed back panel & evaporator is completely covered in frost.
Purchased and replaced Thermostat defrost & defrost heater kit. Both original parts tested okay, but replaced anyway (thermostat was cheap)
Some dust on condenser, not excessive: thoroughly vacuumed entire area in and around condenser & compressor
Fans working
Defrost is now working better but not as it should & fridge and freezer still aren't cold enough. Frost still building up on evaporator
Replaced Defrost Timer, noticed clogged drain, unclogged
Defrost working well; no frost on evaporator, no water at the bottom of the fridge
Fridge and freezer still not cold enough, temp gradually decreasing
Unplug and leave the country
3 weeks later, plug in & things seem to be working well. At center control setting, freezer is -10 & fridge is 20
YAY
Within 12 hours fridge and freezer are again not cold enough
I feel like I'm missing something simple. Is there a reset setting for this unit?
I cannot find much info (beyond parts) for this particular model, all is for french door, this is top freezer, no digital display.
I know it's old but really like the shelf configuration for this unit & it's size and shape fit my space really well so I'm hating the thought of replacing. Actually went shopping before we left the country & was very disappointed, hence the unplug & walk away for a bit.
Edit to note water in the bottom of the fridge was due to a clogged drain discovered when we replaced the defrost timer
Fans working
YAY
