weather_man
- GU2500XTPB3
- Whirlpool
- 6-10 years
No matter which cycle is selected, when I press Start/Resume (S/R), dishwasher goes into 2-Minute Drain (2-MD). Pressing S/R again turns off 2-MD. Pressing Cancel/Drain (C/D) also starts 2-MD; C/D again turns off 2-MD; and so on with both S/R and C/D act as toggle for 2-MD. I can not start any cycle. The buttons and all LEDs work except High-Temp Wash LED will not lite. Regardless of the cycle or options chosen, S/R or C/D clears all lights and starts 2-MD. There is no water in the base and no flashing lights. I turned off the beaker for 5 minutes several different times over the last 24 hours to reset the dishwasher but it did not have any effect.
I ran the Diagnostic Cycle several times with the following results [Interval: Numeric Display(LED, Interval)]:
19: 88(all LEDs lit including High-Temp Wash, 0:06), 18: d1(Normal, 0:02), 17: 12(Rinse Only, 0:02), 16: 16(Normal, 0:55), 15: 15(Normal, 0:05), 14: 14(Normal, 0:40), 13: 13(Rinse Only, 0:05), 12: 12(Normal, 0:45), 11: 11(Rinse Only, 2:00), 10: 10(Normal, 0:15), 9: 9(Rinse Only & Sanitized, 3:00), 8: 8(Normal, 0:15), 7: 7(Rinse Only, 2:00), 6: 6(Normal & Lock, 2:00), 5: 5(Rinse Only & Lock, 2:00), 4: 4(Normal & Soaking, 1:00), 3: 3(Rinse Only, 1:00), 2: 2(Normal, 1:00), 1: 1(Rinse Only, 2:00). Note that the last interval did not run for 3 minutes.
During each diagnostic I could hear the water spraying and the drain worked perfectly. Upon completion the tub was empty. I felt the Heating Element after each diagnostic; it was never hot, only warm from hot water spray. The element looks in good shape. I'll check the continuity and report back. Can the Heating Element really cause all these issues or do I have a bad Control Board or both?
