- 550
- Sub Zero
- More than 10 years
My parents have a 30 year old Sub-Zero 550 with major ice buildup all down the right side of the freezer. After doing a little research, I ordered the drain heater kit (4202160) and plan to install it the next time they defrost it. Other than that ice buildup (and a small amount on the bottom of the fresh food section) the fridge works fine.
I haven't taken the evaporator cover off to look yet, so I don't know if a drain heater was already installed. I see that the right side of the cover was caulked at some point (picture attached).
Right now, my questions are:
- What was the reason for the caulk?
- Was it probably something a tech did?
- Was it an actual fix for water going down the side and freezing?
- When I replace the evaporator cover, should I caulk it again?
