Sub Zero 650 bottom freezer stuck shut
william13
florida
S 650
Sub Zero
Happened suddenly
Right side opens less than inch
Left side does not pull out at all
Rocking in place no help
No water visiable
Turned off power and now I wait
Questions: aside from pulling out full unit and tipping back, what can I do?
paulhl
Flemington NJ
You're going to have to determine whether it's freezing on l/s (ice maker) or r/s (freezer drain) or after waiting something is not jamming on the ceiling, not easy. If it's ice it will take a while. Tipping back won't help
william13
florida
So all I can do now is wait!? I dont feel the seal is frozen at I can slightly move right. Its definately on left side. thank you. so now I must determine if ice maker or jammed object.
william13
florida
More info:
Able to open freezer door after about 5 hours of defrosting.
Found the ice cube bin a sheet of solid ice and below the freezer tray (on bottom of freezer) was (is) a solid piece of ice also. What went wrong to cause this?
I found this on web: am I on right tract:?
paulhl
Flemington NJ
Obviously overflowed. When I run into this, after checking water supply for proper valve on plumbing, I replace the ice maker + valve in SZ.
william13
florida
Thank you. The funny thing is that I always by cubes at store. If I shut icemaker off (button in top fridge) would this prevent the leakage?
william13
florida
That makes sense. Is there an internal shut off valve or might it be on the wall behind the fridge?
paulhl
Flemington NJ
Normally it's below the unit, even tho it's on rollers it's still a pain to have to pull it out. Remove the toe kick, valve is on l/s, see where tubing to it is going.
