- Summit
- 6-10 years
need some advise I got a summit wine cooler. if had a small line on the 4mm OD copper tubing that goes from the compressor to a small holding plastic water holding area, I am guessing it uses the heat from this tube to help get any water evaporate from this collecting bin any water sit in when the unit defrosts. there is a small hole in this line.
I do have brazing rod and torch, I found the 4mm OD copper tubing no problem on line. I was planning to cut the section with the crack in it and replace that small section.
My issues is I can't find any 4mm ID copper coupling to join up my new line.
I did find 6mm x 4mm copper tubing. I guess I can buy that and just cut 2pc at 1" long kind of a waste. any suggestions?
