Sump Pump and/or sump pump seal replacement to fix E15 error code on SHE7ER55UC/50
islandlife
nanaimo
SHE7ER55UC/50
Bosch
The source of the E15 code on my Bosch dishwasher appears to be coming from the sump. There was a small amount of water under the sensor float and evidence of water at the gasket between the sump and the tub. I can't see any other signs of a water leak.
Do I need to replace the entire sump OEM part #00668102 or can I replace just the seal OEM part #00263102
Is there a benefit to replacing the entire thing if there appears to be nothing wrong with it? It seems like a lot of effort otherwise.
Here's the sump seal for your model:
Sump Gasket 00263102
Here's the entire sump assembly for your model:
Sump Assembly 00668102
I find it more beneficial to replace the entire sump assembly that comes with the sump seal, when I replace the ones for my customers. I don't like call backs.:)
No, not really because you have to remove the entire sump anyways to replace just the sump seal.
