Superba KESC307 repair manual
hametown
Akron, OH
I have a Superba KESC307 stove with a dual burner that only knows one setting - dual. I could test the burner control, but I don't even know how to safely get beneath the control board to check it out. I am hoping a repair manual might just do the trick. Does anyone know where or how I can obtain the manual for this unit? Thanks!
Yes, but you would need to post the complete model# of your range.
KESC307 is just a partial model#.
The model# tag is located at the very bottom of your range on the front left or right side frame, you would need to pull your storage drawer out to see it.
Here's the service manual for your model: https://www.dropbox.com/s/0udmmcqalgxhxyc/KA-ELERANGE2001.pdf?dl=0
Its 1 of 2 parts that's bad, either the burner switch itself or the burner assembly. You would need a multimeter to ohm test for continuity of that dual burner.
For a video to show you how to ohm test it, click here: Element Testing – Electric Stove Repair
Here's the dual burner assembly for your model:
W10823692 Large Surface Element
Video included in part link.
Here's the dual burner switch:
8203536 Infinite Switch
Video Included in part link.
hametown
Akron, OH
Superba KESC307HBS0
Thanks, Jake, for the tech information. That should do the trick. I really appreciate the help.
