superdaddyo
tim cole
michigan
I've got a maytag microwave model no. aco1520ac and every thing works fine except for the start button. I can even warm my food up using the pre heat mode but I cannot start the unit using the start button. Will I need a complete touch pad or can I order just one micro switch?:confused:. Thanks for a great resource. you've saved me many moneys and made me look like I knew what I was doing !
TechnicianBrian
Portland, OR
The buttons are part of a switch matrix and most likely, one of the leads to the start button has failed. You can try to remove the ribbon cable that runs from the membrane to the control board and clean the contacts with a pencil eraser. If that does not help, then a switch membrane
will be needed to resolve the problem. The old one will peal off the panel as it is just glued in place. Clean as much of the old adhesive off before applying the new membrane.
