T1576 Miele dryer not completing cycle
indianajonesy
South Carolina
T1576
-major brand-
Dryer starts, drum spins, fan sounds like it's running. About a minute or two into the cycle, the anti-creae light starts flashing and the dryer goes into cool down mode and then stops. I went through the technical service manual and did a diagnostic, which returned the following fault:
"NTC at heater bank open circuit"
What causes it to have an open circuit and is there anything else I should be checking? Does anyone know what the part number is for that sensor? Any help would be appreciated before I start this.
indianajonesy
South Carolina
Digging a little deeper, residual moisture sensor test (service mode>rotary iron) and the cooling down light flashes, stating that the residual moisture sensor also(?) has a fault. Not sure if this is the cause, related, or what the deal is...
