FIXED T36IT70NNP/04 Thermador Refrigerator - Compressor inverter
epttg
T36IT70NNP
Thermador
I have Thermador T36IT70NNP-04. Freezer compressor stopped running. The inverter board has no output but has input voltage. I ordered compressor with inverter. But replacing compressor is a big job. The compressor is most likely fine. I'm just wondering if I can just swap the inverter. New and old have the same in and out voltage and frequency, same 1/3hp, 1PH in and 3PH out, 2.1A out. The only difference is the new one has 3.3A in while the old has 2.1A. Both are Embraco inverters.
Models:
Old: VCC3 1156 06 F 03
New: VCC3 1156 20 F 08
Can I just replace inverter?
I've never tried a different manufacturers inverter. I know the 3-6 VDC signal voltage varies the frequency and the inverter selects the voltage based on that frequency. Is there a frequency (Hz) listed on the inverter? Do you have the 3-6V signal voltage at the inverter?
epttg
Frequencies are the same:
input 120v 50-60 hz
output 230V-53 TO 150Hz
The only difference is Amp rating.
I think it will work but I'm not 100% sure. I don't think it will do any damage if it doesn't work. The higher amp rating is probably for a different size compressor. I know the windings resistance will vary across different size machines. Anywhere from 6Ω to 12Ω
Hi Jake,
Once he found out you had to buy the compressor to get the inverter, he didn't order it. He used an inverter from another machine.
