FIXED TAWS850PQ0 Estate Washer Loud noise during the spin cycle
cznlzq
IL
TAWS850PQ0
Estate
Whirlpool TAWS850PQ0 Estate Washer
Loud noise only happens during the spin cycle
Need help for fixing that loud noise.
Thank you.
Take the cabinet off and you can get a better idea where it's coming from. Remove the two screws in the console end caps and fold the console back against the wall. Then disconnect the lid switch connector. You'll need to use a small piece of wire to bypass the lid switch so you can run the machine with the cabinet off. Remove the two spring clips holding the cabinet top to the back wall then lift the cabinet off. Check if the inner tub is loose.
Yes, I agree with Rick, it sounds like the inner tub is loose.
You'll need a spanner wrench to remove the inner tub: Spanner Wrench
Here's the tub drive block for your model you can order here if needed:
Drive Block WP389140
Here's the Video: Top Load Washer Drive Block Video
You can see the comparison here:
See the one on the left, its the old one, the one on the right is the new one. It has to have those 2 ear slots. Does yours look like the one on the left or right?
cznlzq
IL
Yep, it’s the drive block.
We replaced it and the loud noise is gone.
Thanks for all the folks for the info here.
Appreciate it!
