G41775
- TEDS740PQ1
- Estate
- More than 10 years
I have been trying to figure out the issue with this dryer and cannot find the fix.
First, it would not heat and timer would only advance in timed cycle but, it would not cut off at end. I found the element had a break in coil so I replaced it. I also replaced the timer and cycling thermostat. Now it will heat but, timer will still only advance in timed cycle and will still not cut off. When I replaced the parts I made sure to replace wire for wire on new part to make sure it was right. What is the next step to figure out problem.
