Temp Issues, Silhouette Beverage Center, DBC056D1BSSPR
cmlorenz
CA
DBC056D1BSSPR
-brand-
Hi, I have a Silhouette DBC056D1BSSPR beverage center. I've had it for about 4 years. Recently it's started cooling WAY below the set temp (usually have it set around 45F), to the point that beverages are freezing, cans are exploding, tops are popping off...
Naturally it's past its warranty...curious as to whether I might have an issue with the temp sensor or something else within the temp control system and could potentially repair/replace this myself instead of chucking the entire unit.
Thanks for the help!
I've never worked on this brand, but its basic refrigeration 101, if its getting too cold then it has to be the temperature control sensor that's bad.
Here it is for your model:
Thermistor DG8-25-B
