Thermador double oven SCD302TP
Artesia
Seattle
SCD302TP
Thermador
Hi, my thermador double oven does not heat up past 120 degrees or so on the lower oven only in convection mode. Regular baking works. Also the self clean function doesn’t work on the lower oven. The upper oven works fine in all modes. Thanks!
Not many many techs work on Thermador, so please be patient till someone with knowledge of this issue can help you out. Thanks!
Other than that, You can contact Thermador at 1-800-735-4328 to have a tech come out.
